Duel fuel-flow sensors
kirkbauer
Active Member
I'm building an RV-10 with traditional fuel injection system and an Andair valve. I was curious if it was possible for the Garmin suite to totalize the fuel from each tank? I don't see that there is a sensor on the fuel valve, but could you put fuel-flow sensors on the two inputs of the Andair valve and have Garmin totalize each tank separately?
