Trying to install DW on 2003 vintage RV7. Made the cut out in the le - easier than anticipated. Cut the plexi - easier than anticipated. First lens - ugly gap. Figured I just didn't fit it right. Second lens, careful as I could be, pressed firmly into leading edge - still ugly gap with final install (with added bonus of a crack...) As someone pointed out in a previous thread, if it's not the right shape, it's just not going to fit.
Any ideas for either getting a better fit, or another lens kit that will fit in the hole from the DW kit? The le has not been attached to the spar yet. I'm torn between "fill the gap with clear silicone and 'build on'" versus scrapping the le and building another now while it's easy to do.
