Capflyer
I am confused as to the proper wiring for a dual LSE Plasma II with two batteries and one alternator system. In my wiring, only one battery is being charged by the alternator at a time and the plane is only running on that one battery. If I connect the controllers to only one battery then when I use the other battery it is not connected. If I connect one controller to each battery then still only one of the batteries is being charged and the other is just running the ignition and drawing down the battery.
I have searched for posts and talked to Klaus. No relavent posts and Klaus doesn't seem to want to understand my set-up. The dual power supply drawing that LSE provides doesn't really address my issue as the aux battery in the drawing is just a back-up battery.
Thoughts, drawings, ideas, all happily accepted.
