Does anyone know whether you can connect two antennas (top & Bottom) into one comm? I haven't seriously looked for any info about it as yet, but figured the brain trust here probably knows the answer. I am using an SL 40.
Thanks in advance!
Bob Archer sells a box that permits you to use one external comm antenna with 2 transceivers. It gets wired to the PTT switch on the back of your radios so that whatever transceiver is in use gets the path to the antenna during transmit. During receive, both use the antenna. It's pretty inexpensive - maybe $150? I can't recall exactly. (I have one in my RV9A). Bob is listed on the Kitplanes list of antenna vendors - call him to order. - Robert
