Same redundency? Does anyone load test their batteries every 6 months? If you don't then you have no idea of it's ability to carry your electronics, it may start your engine, but your 22 a.h. battery may only be half of that capacity when you need it. And the 22a.h. rating doesn't mean you can keep 22amps going for an hour, those ratings are usually done more like 4.4 amps per 5 hours, and that's a fresh battery. A fresh 22a.h. is more like maybe 10amps the first hour and then way down from there, and that's a fresh battery. So say you have two, that's way better than just one, but unless you have two fresh ones, you really have no idea how long you have. But if you replace the main every year and rotate the old main to the standby, you are probably never going to be in trouble. I am opting for an SD20 in the standby vacuum pad mounting and dual batteries, but my second one is going to be a small and not placed in the back. I have a really power hungry panel planned and with my setup, I won't have to shed any loads. My weight penalty will be minimum, and my cost will only be a few hundred more for the SD20.
