I have a '-1' fuselage kit.
On page 8-28 of the instructions, It has me cleco up the F817LR-1 Side plates, F856-1 spacers, and WD-808 Front seat backrest. I am then to Match drill the feet of the WD-808, F856 -1 and F816-1 Cockpit Rails (#30). My problem is this.
The plans show 'no holes' where the 856 spacers and the holes in the WD808 feet line up. There is also no hole in the 816 cockpit rail. However the 856 spacers provided in the -1 kit have 3/16" holes prepunched in the location of the holes of the WD808. I could cleco the spacer on TOP of the F816 cockpit rail, match drill those two, put the spacer back in the correct position, and then drill the feet on the WD808. Or should I cleco the spacer on top of the rail, centerpunch the locations, put the spacer back in position, and then drill?
If any '-1' Fuse kit builder has gone thru this already, please let me know how to proceed.
Thanks in advance,
Thanks in advance,
