rv8_builder
Active Member
Hi RVators,
We match drilled the U-804 inboard main gear attach brackets using the 7/16 hole in the gear legs as a guide. We expected these holes to be centered in the U-804 brackets but instead they are offset outboard as shown in the picture below.
On DWG 75 it looks as if the three holes are supposed to be in line.
Do we have an edge distance issue here or is this normal.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
