I have been having one heck of a time getting the canopy to fit up to the front skin properly and have had to have the holes on one side filled twice and the other side once. It seemed like it was always off 1/16 - 1/8" no matter what I did on the left side. I called Van's and disscussed it with them and told them what I thought would be a better procedure and upon agreeing they said it might be a good idea to post it.
This could be common knowledge to some but it wasn't to Van's. I took a 1/4" transfer punch and marked the spot since it was too close for my 90 degree drill,(use the 90 if you can) removed the canopy, drilled the 1/4" holes and reinstalled the canopy to see if the holes lined up properly before drilling for the 3/8 bushing. This way if there is an adjustment you can do so by adjusting the 3/8 bushing the proper amount. I used a 1/4" file to adjust the hole then drilled with a new 3/8" bit. I found that even when the spacing is good before the front skin is rivetted on it tends to move once it's hammered down. Hopefully this will help someone else avoid sleepless nights and turning the air blue.
