If your part has final size holes but the part it attaches to has no holes, is it best to match drill using an undersized bit to create the virgin holes, then use a reamer to upsize? Or do you just use the final size bit and drill once? I want to minimize possible damage to the existing final size hole and putting one bit through it vs two seems like the safer option.
