blueflyer
Im sure others have done this before me, but it has worked so well in a few places in the construction of my emp, I thought I would post it. This trick helped me to drill the elevator horns perfectly. Once I got the counterweight flush with the surface of the stabilizer, I put a little of my daughter's paint on the end of my bolt.
Then I stuck the bold thru the hole and touched it to the elevator horn.
And voila, it showed me where to drill.
Then I just drilled a #40 pilot hole in the center of the paint mark, then drilled to size. The placement was perfect.
