The HS is mounted in the rig, everything is measured up, and I can start drilling holes. The manual say start at the intersection of HS-408/rear spar and go up and out in each direction from there. This is a bit vague, should I go up the HS-408 and the HS-407 and then out? or up and out at the same time? Should both sides (up/down) be done simultaneously? hmmmm ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
