Stansuski
Member
Hello, I am going over a new to me RV-12, one of the many things I am correcting is the flaperon setup, to say it was not to spec.is an understatement, I have become intimately familiar with this one now
. My current project is measuring all control linkages and I had to replace the mixer due to improper assembly ( long story), all control tubes are now exactly to spec. , since everything was wrong now that the mixer is correct and all other parts proper length as you can imagine the flaperons are out of sequence , I have new torque tubes but have original torque arms which means the original #30 holes have already been enlarged, I am looking for help in deciding the best way to drill new tubes using original arms, those of you that have done this could you please give me a heads up on the best way to do this and did you remove the tube/arm assembly to drill bottom holes or did you just drill all the way thru from top? I know this is a critical procedure and want to do it correctly.
Thanks in advance,
Stan
Thanks in advance,
Stan
