LettersFromFlyoverCountry
In the avionics kit, chapter 42 Page 8 Figure 1 has you enlarging a hole to 5/16 of an inch. This really should have been an instruction way earlier in the instructions because it is very difficult to get anything in there to drill a straight hole. Observe:
You have approximately four and a half inches of room to work or roughly the width of two wing spars.
It seems like a right angle drill would be the idea here but I don't have one that will fit in there and I'm wondering if anybody else has reached this point and has a solution and if so and it requires a particular tool which one are you using?
This might be an artifact of fuselage kits from before the avionics kit was available.
