wirejock
Ok what the heck is going on with my fuse?
The manual is specific about making sure the aft fuse is straight before drilling. I've got three saw horses per the manual. I hung four plumb bobs from the first three bulkheads and off the end. A center line was drawn on the inside of the bottom skin.
Front is easy to plumb. Rear falls right in line. The second one is about 1/32" off starboard. The third about 1/16" off starboard. If I try and get the third one on the line, front and rear go off to port. Correcting fore and aft forces the center back off and I end up in a Mobius Loop. Holes seem to line up fine. I've moved saw horses around fore and aft. I've tried 100% clekos and also pulled almost all the clekos and started over. No holes have been match drilled yet because I don't want to drill in a twist. Two days chasing this. Maybe I should not use the second and third plumb bobs.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Got any ideas?
Got any ideas?
