WingsOnWheels
If the weather is good this weekend, I plan to pull the fuselage out of the shop, mount the wing, and drill the main gear mounts. However, there is an issue I would like to get some input on. I am hoping Vans will be open Friday so I can give them a call.
The forward flange on the gear weldments that bolts to the lower longeron doesn't match the plans. The plans show the strut welded to a midpoint in the flange and a bolt forward and aft of the tube (see image)
The weldment as provided has the strut tube biased more towards one end of of the flange. The red dots in the second picture would be the plans drilling locations (the dots are just for representation, not exact points), but putting a bolt below the tube on the corner of the flange would not provide sufficient edge distance or the nut would interfere with the weld. I could put two bolts on one side of the tab (black dots), but the edge distance on the longeron would then be questionable.
How did others deal with this part of the weldments? Pictures would be appriciated.
![cimg4650.jpg](/proxy.php?image=http%3A%2F%2Fimg41.imageshack.us%2Fimg41%2F2559%2Fcimg4650.jpg&hash=6feb4a9674dc204cba3ef594581ec136)
![cimg4652p.jpg](/proxy.php?image=http%3A%2F%2Fimg828.imageshack.us%2Fimg828%2F3577%2Fcimg4652p.jpg&hash=0b54fb5c6dbf77ca9df5603ab579beb6)
