mculver
I keep thinking about the cost of a dimpler -- both the financial cost and the space it takes in the shop.
Would it make sense to manufacture a shaft with the dimple set that fits into a drill press? No need to turn it on -- you would simply be using the mechanical advantage associated with the handle that ordinarily lowers the bit into the work.
Mike
Mike
