Pool Shark
Active Member
I'm getting geared-up for my RV build; tools just started arriving including the DRDT-2. I just finished assembling it and was about to start building the small table described in the accompanying plans, when two questions arose affecting how high the surface of the table should be:
1) I was thinking of using the female die on the bottom (to avoid marring the skins with the "tit" on the male die when sliding the skins around; I read somewhere on the Forum where another builder suggested this). My female die is 3/8" thick, while my male die is 1/4" thick; so which die I use will affected the height of the table I build. Is there any reason to use the male die on the bottom instead of the female die?
2) The table height dimension in the DRDT-2 plans will result in a table that is approximately 7/8" lower than the face of the lower die. This seems odd since I would have thought the goal was to have the carpeted work surface exactly level with the lower die face.
Am I missing something?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
