HI,
I have a Woodward prop governor on an IO-360. The unit is installed upside down? I have seen these units with the actuator arm on the top side when viewed from the back -- this one is set up so that the arm is facing down! If I hook up the governor this way with the cable entering from the left the cockpit lever will work in reverse. Does anyone have instructions or drawings for disassembly of the Woodward governor and maybe instructions for rotating the arm/sping/stop assembly to the upright position? Any drawings/instructions for using the Vans cable mount with this governor? Any information is appreciated!
Thanks, Jim
Thanks, Jim
