Seems to be two approaches to scuffing the aluminum prior to applying DPLF, most say use red scotchbrite pad but some say use 80 - 150 grit which is what the data sheet says. I tried both on the underside and the grit really scratches up the surface and I am concerned the scratch marks will show through. Will the bond be good with the scotchbrite method.
Second question is the time available to spray the topcoat (DCC Concept single stage), data sheet says from 90 minutes (2 DPLF coats) to 7 days, some people say wait 2 days for some curing and others say 7 days is the absolute outside before you have to scuff and reshoot another DPLF coat. Would appreciate some feedback from successful PPG users.
