I received the finishing kit this week and have started on the dreaded doors. I am going to move through this section extremely slow to reduce the risk of messing up. The first problem I encountered was with the predimpled holes you're supposed to drill. Several weren't noticeable so it's not completely apparently with the alignment. Good news is at least the forward set was noticeable so I went with that.
I did the initial trimming and best lined up the doors halves accordingly. What can I do to ensure these are in the right place and I'm not going to encounter issues in the future... I'm sure I will anyhow.
![](/proxy.php?image=https%3A%2F%2Fs23.postimg.org%2F4rsuwdqx3%2FIMG_2973.jpg&hash=28d2395151d310ca665c3b4c00e384a4)
![](/proxy.php?image=https%3A%2F%2Fs23.postimg.org%2Fyxr9b5xtz%2FIMG_2974.jpg&hash=89c8a0dddd2099b8716c117f0e9b8fd4)
![](/proxy.php?image=https%3A%2F%2Fs23.postimg.org%2Ffh6jon2pz%2FIMG_2975.jpg&hash=5f2c087f21438cd35dbe9e732019b94a)
My thought is to use duct tape and get the placement exactly right. Maybe measure the scribe line in reference to the cabin flange. Then work from the bottom up using the index holes in the fuselage, then match drill around the windows... then keep weight on the top and check the hinge orientation? Any advice would be greatly appreciated!
