CharlieWaffles
So I know there are some after market handles/latches from Hendrinks and from IFlyRV10, but both have some drawbacks in my opinions. Any other options to cosider?
Hendricks:
1) Requires you to roll your own pins/shafts
2) Interior handle is connected to main assembly, so outside latch is far forward on door
3) Handle is wider than door depth so requires some glass work
PRO
1) Interior handle is better than stock handle
IFlyRV10:
1) Requires the secret hole/button to undo inside latch in addition to rotating exterior handle
2) Uses stock interior handle (can be dressed up with Aerosport Products though)
I like the IFlyRV10 handle, but dislike having to fiddle around with undoing the inside latch at the same time. Is there a way around this yet?
Hendricks:
PRO
IFlyRV10:
