I just finished installing a set of flush handles from iflyrc10.com. These handles just look so much better than the Std. Van's handles and they work very well when installed correctly. Be prepared to spend a bit more time on the installation though, these handles requires more fitting and a couple more holes cut in the door.
Thanks for the replys. I'm wandering if God forbid, one and an unfortunate incident and had to be removed from an aircraft with flush handles (read, not standard type on an aircraft) by an outsider in a hurry , how do you think they would fair out?
