Mike S
Senior Curmudgeon
I just ran into a "Gottcha" on the door hinges, one of those things that can be easily overlooked.
The hinges on my right door were installed (by the original builder) in reverse, and I also found the same thing on a buddies plane.
Take a good look at the detail on page 45-06, drawing of the door hinges. The hinges are built with a tilt to the axis of the hinge pin, and the correct installation is to have the lower side of the tilted pin aimed at the other hinge.
Like this;
It would appear that the idea here is to counter the misalignment that will be induced by the curvature of the canopy cover. If the hinges are installed in reverse, the misalignment is intensified instead of mitigated.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Like these are![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
For those of you who are still building, or removing the doors to do a safety catch, be sure to check for the hinge alignment, and correct it if needed while the door is off.
My plans are a revision "0", so this may have already been addressed------not that there is an error in the plans, just that the direction are not clear----the hinges are designated "L" and "R", instead of front/rear. Actually best would be "front right" "front left" ETC.
Even though my right door is set up incorrectly, it appears to be functioning well, I can not feel any binding----but I can sure see the hinge pins are not on the same axis as each other when I look at it. My guess is the structure is flexing enough to allow the needed movement?? As can be seen in the photos, the door side of the hinge is not accessible without damaging the upholstery.
One of those things that can bite you when you get a partially completed project![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Like this;
![P6050012.jpg](/proxy.php?image=http%3A%2F%2Flh4.ggpht.com%2F_A1sW0YKpru4%2FTAxOZZgGJ2I%2FAAAAAAAABmQ%2FgS9KB2Ris18%2Fs720%2FP6050012.jpg&hash=cc9e40c7bfe6a2a3a7f5f3153d24b294)
Like these are
![P6050014.jpg](/proxy.php?image=http%3A%2F%2Flh3.ggpht.com%2F_A1sW0YKpru4%2FTAxOaDZa2II%2FAAAAAAAABmY%2F6_ht8WATjpQ%2Fs720%2FP6050014.jpg&hash=a9c7eff3a43ef9e286882c80c796564a)
