Polish the C-1007 to make sure that there isn't any corrosion on it. Also make sure that there aren't any burrs or corrosion on the inside of the door handle.
Mine were rough too, Although awkward, I used a file to get rid of the material that was causing the friction.
The springs are plenty strong. You just need to determine was is causing the friction and get rid of it.
bob
