I'm sure these doors are going to be the death of me!
Like many others, I have changed the supplied seals for automotive style seals fitted to the frame. After much work and money spent on various size seals, I have managed to get one side to fit - hopefully the other will be easier with the experience gained. However, there is still an issue.
The door is easy to close from the inside because the lever pulls the door forward and down into the frame as you operate it. The plans were not very clear about which way the external handle faces but it seems it should go to the rear. This means that when you try and operate it, it tends to pull the door back and up out of the frame. Coupled with the shorter lever, it makes closing the door from the outside much more difficult.
So, do I have the handle the right way round? And can anyone see any problem with facing the handle forwards?
