Jeff R
One great hint I picked up here was to not install the firewall when the instructions say to. I was a little hesitant to forego the installation, but after checking that I could indeed get the firewall back on again if just left it clecoed in, I am so glad I did.
I was really glad when I started installing the fuel vent lines and landing gear weldment. Everything was easy to reach (well, relatively easy).
When fitting the rudder components, I just pulled up a chair and it was piece of cake.
And, today, I jump ahead a bit and drilled the engine mount to the firewall. I just laid the firewall horizontally on a table, positioned the mount, clamped it down and drilled away (putting in a bolt after drilling each hole, of course). In reading other posts on drilling the engine mount, I thought it was going to be a pain and I would end up breaking several drill bits, but in maybe half an hour, I was done.
And, while it is still off, I started to drill the holes for the other firewall-mounted components, namely the master and starter relays. This is easy to do with the firewall lying flat on the table where gravity holds things in place for positioning and drilling.
So, I highly recommend delaying the attachment of the firewall until after you have taken delivery of the finishing kit (and firewall forward kit, for that matter).
