UnPossible
Hey - getting ready to start the engine for the first time and found one of those things that will keep you up at night.
I was going through my fuel system to make sure that everything was locked down... when I checked the one of the fuel lines going into the Andiar valve, the nipple came out of the valve still attached to the fuel line
..... none of the screws that attach each of the nipples to the valve were installed ![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
When I got home, I found the box the valve came in... and there were the screws with a note that they left them out incase you need to change the orentation of the nipples. This is the first thing in my build that I have screwed up so far that I think really could have killed me.... so if you are using an Andair valve, you might want to check to make sure you have those 8 small, but very important screws installed.
Jason
Jason
