Aviaman
What are the likeliest reasons you will be forced to stay somewhere overnight (not including WX)? IMO the 2 biggest causes are flat tires and dead batteries. Can we carry items that give us self sufficiency, where we can fix things quickly?
My idea is to carry a spare wheel assembly, so that no splitting of the existing wheel is required. That greatly simplifies the fix. A jacking method is still required. Jacking on a windy ramp is problematic, so if you carry jacking items, you may still need to move inside of an FBO hangar for an hour. The jacking equipment might be too bulky to carry, and the assistance of an FBO might be needed.
What about the battery? An external power port allowing jump starting will fix the dead battery problem. On my previous RV-6, I fashioned a welding cable and connected it to the battery in the battery box. It was protected with grommets and terminated with a trailer connector. The cable was a few feet long and kept coiled on the floor with a protective boot to preclude a short. A mating cable was also fashioned to connect to a jump starting battery source. Any other ideas or better way to deal with this, or other, out of town problems ?
