Briand,
I seem to remember some of the spacer or angle obstructing
the engine mount holes after riveting the weldments on. You
will probably use these holes to mount the firewall to the jig.
I ran a #12 drill through them to clear the holes out. I wouldn't
drill them to size until you get ready to attach your engine mount.
Use your engine mount as a guide when you drill to size. Each
mount has a mind of its own.
Hope this helps, Pat
