Rob Kochman,
Your statement, that I must have switched my Left and Right Elevator front spars, is precisely correct.
I'm 100% certain that I had everthing perfect up until priming the elevators, and then I mixed those two up.
Basically I had a system, where all of the "Left" elevator parts would be on the South end of the garage, and the "Right elevator parts would be on the North end of the garage.
While, this system has been working well, I do recall one evening after a 14 hour binge on building, that I got a little confused, and switched those two! Grrrr!!! I'm frusterated with myself.
The good news is, if I unbolt my Elevators, I should be able to drill the lower hole, and add a snap bushing there.
Yes, there will be two 5/8" holes near each other, but structurally the elevators will still be sound.
Ron, thank you again for being so observant. Pictures really do "say a thousand words", and you've caught my blunder, in that I am indeed using the wrong cable routing hole!
Best Regards,
Andrew Boyd
