I had the opportunity to finally test all of my avionics last night. The only issue I encountered was distortion of the sidetone when transmitting on the pilot side. Reception on a handheld radio was clear however and it is clear when speaking through the intercom (hence, does not seem to be a headset or wiring problem). I did not get similar sidetone distortion on the co-pilot side using the same headset.
I was able to completely clear it up by decreasing the sidetone levels on the comm to 40 (default was 128). Anyone else encountered this? Hoping Stein will see this and might have some ideas as well. Perhaps all is fine now that I have cleared it by changing the radio settings. However, I did not expect to have to make this change and did not recall anyone else reporting a similar problem.
Jeff
Jeff
