Have been recording fuel consumed on engine shutdown on my G3X Touch (GDU460 Running V9.31) and then carefully measuring actual fuel top ups so I can fine tune the K-factor on the red cube FT-60 flow transducer (Use the adjust fuel used method over the manual adjustment of k-factor in config mode.)
Have noticed after re-fuelling and restarting the G3X the amount it had previously recorded for fuel consumed has slightly changed before resetting or adjusting it?
Will attempt to get some screen shots on next shutdown/refuel however has anyone else noticed this behaviour on a G3X please?
