Although I installed the replacement sight glass in my tank before completing it, I find it a pain in the butt to use. I find you need good light and have to rock the aircraft to see the level of fuel. When pumping fuel into the tank one has to walk around to the other side to see where you are up to so you don?t over fill the tank. Now I use a dipstick as people have been using for many years, the most fool proof method yet. I use a 31 inch piece of steel measuring tape coated on one side with tank sealant so it has a mat black surface to show the fuel level and a blob of sealant on the end so it doesn?t scratch anything going down. The tape bends to the shape of the filler tube as it is inserted and is easily stored behind the seats in the u section running across the aircraft.
My Dynon fuel gauge works well but I still have the belt and braces approach to flying
Tony
Tony
![dipstick.jpg](/proxy.php?image=http%3A%2F%2Ftonyearle.com%2Fdipstick.jpg&hash=d387f7c674cfe285d02794a8e0d816a2)
