When building my Rocket I made a plenum to assist with cooling. To provide access to the dipstick I put a cone around it, and then attached some scat to the plenum directly above the cone. When installing the plenum the scat is compressed down around the cone - this maintains the seal around the dipstick so the plenum does not lose pressure.
Now I want to install the CPI electronic ignition, and want to put the coil packs inside the plenum. However one plug boot interferes with scat.
My question is: Regardless of the electronic ignition, is there a better way to provide access to the dipstick when using a plenum? How have others done this?
Here is the top of my engine with the plenum off - the CPI coilpack is roughly in position:
Here is the bottom of my plenum with the scat attached:
![Dipstick.jpg](/proxy.php?image=http%3A%2F%2Fwww3.telus.net%2Fpublic%2Fmolsons%2FF1%2520Rocket%2520Parts%2FDipstick.jpg&hash=116c3780db14ff47c08aad9949271846)
![Plenum%20Scat.jpg](/proxy.php?image=http%3A%2F%2Fwww3.telus.net%2Fpublic%2Fmolsons%2FF1%2520Rocket%2520Parts%2FPlenum%2520Scat.jpg&hash=a56cf04231da19006ed25d9b484b78d0)
