John Courte
Sorry, can't remember the number of the part, but it's the big rib
that attaches to the lower end of the rudder spar.
Last night, I dimpled this part, with a squeezer, and now it's got
a nice, smooth warp to it. As in, if you lay it on the bench
flanges pointing up, the whole thing is bowed upward from ends to middle.
Dimpling warped the rib. This rib is made of the same material
as the spar. Was I supposed to dimple this thing while it's
clecoed to the skin? Furthermore, is it OK/recommended/advisable
to flute this part back into a straight line? Dimpling the spar itself
was OK, no problems there, and the upper ribs, the ones made of thinner
material, no problems there either.
Other than that, it's all going swimmingly. Since I received the empennage
kit, it's been 5 months, my website's gone down twice, but I've completed
the HS and VS, minus the fiberglass tips. Clearly, I'm in no hurry, but I'm
anxious to be done with the empennage.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
