Building an RV-10. On Page 9-9 of empennage kit figure 4 I am trying to dimple the aft end of the E-903 outboard tip rib. The skin overlies this and is dimpled to fit in the dimple of the tip rib. The last hole on the top and bottom of that rib. #40 hole. The pull rivet dimpler I have uses a finish nail whose head is bigger than the #40 hole so I can't fish it through the hole to slide through the pull rivet dimpler. How do I dimple those last two holes, one on top and the other on the bottom of that rib?
