I dimpled and backriveted these 3-3 rivets, using the dies I purchased. They looked relatively smooth and flush, but I've recently seen an RV with rivets that don't seem to have as much of a radius ring around the rivet. Instead, the one I saw didn't seem to have any transition between rivet and flat skin.
Would any of the experienced folks care to weigh in on if the dimples look correct? I'm using a compression dimpler (for noise consideration), and I've already tried adjusting the ram to press harder. Thanks.
