Well it took a while, but I finally did it. While dimpling the right fuel tank skin tonight, I punched an undrilled hole next to the one I was supposed to punch. The mistake hole is only about 1/16 of an inch from the original and is not full size. The remaing metal between the two is very thin and recessed. The mistake hole was not fully dimpled. My question is...Is my skin toast? The rib flange still covers up both holes and since it would have a layer of Pro-Seal on it would it still be a concern? Do I have to worry about cracks or leaks? Any suggestions would be much appreciated.
Larry
Larry
