David Paule
I wonder if someone can find out these dimensions for me?
1. The wing chord, leading edge to trailing edge.
2. The chord of the horizontal stabilizer, leading edge to trailing edge.
3. The horizontal distance between the wing's trailing edge and the horizontal stabilizer's leading edge.
4. The height of the vertical stabilizer, along the aft edge of the VS-1201 skin.
5. The vertical distance from the pivot hole of the horizontal stabilizer, in F-1211C down to the bottom of the F-1211 bulkhead, ideally vertically down to the belly center line at the skin.
6. The prop diameter.
Thanks very much!
This is to help me locate where the main gear should go on a taildragger conversion. Yeah, I haven't given up that idea yet.
Again, thanks!
Thanks very much!
Again, thanks!
