Dimensions request
Status
Not open for further replies.
RVZoomie
Active Member
I have a set of preview plans but can't find the exact dimensions of the rear fuselage from the back of the baggage compartment aft. My drawings don't even show a scale so any information would be much appreciated. I'm trying to build a custom canvas 'tarp' that will span the entire length to serve as a gun/ski/golf tube. Thanks.
Approximately 53" from the baggage campartment (upper part) to the bulkhead just forward of the HS spar.
still looking
Guys, I'm still trying to find the dimensions of the -8 rear fuselage beginning at the aft of the baggage compartment to the empennage bulkhead. If someone could give me the width at each bulkead and/or the taper it would be greatly appreciated. I'm trying to build a 'golf/gun/ski tube' net and would gladly supply a template to the rest of the folks out there. Much appreciated.
These are approximations as I can't at this point get to the bulkheads in question:
F-808 (back of upper part of baggage compartment) 13 3/4"
F-809 8 1/8"
F-810 small hole only (4"?)
Hope this helps.
Status
