Can anyone building an RV4 confirm whether U-415X is the current model main gear leg for the RV4 ? That part number has no description in the Vans online store but from the format of the part number I believe it is an undercarriage part and the price is pretty close to other main gears. Is the left and right gear leg identical (same part number ?)
If someone has one of these in their shop or in a build, could you confirm the length from the upper end of the rod to where the theoretical intersection of the gear leg and axle portion would be, and the approximate included angle of the bend of the axle portion of the gear. I have heard than on the shorter RV4 gear the nut to nut distance of the gear is 74".
Thank you
Keith
Thank you
Keith
