LRingeisen
Have you ever wondered if your logbooks are covered under your insurance policy? Well, the answer is not really. Although the physical logbook may be covered, there is no coverage for the document reconstruction. This means once the information is lost, it?s up to you to recreate it. To make the aircraft airworthy, the aircraft and engine logbooks must show the required inspections and AD compliance. We recommend keeping a backup electronic record by taking pictures or scanning the pages of the logbook. Not only will this backup keep you flying, it will maintain the value of the aircraft by having complete logs. Lost logbooks can be difficult and time consuming to recreate. If you?ve lost or misplaced a logbook, the last shop where you received an annual inspection will be your first stop. Many shops have switched to electronic recordkeeping as evidenced by printed stickers in your logbook as opposed to handwritten or ink stamped notations. As long as the shop has a record of your completed annual (electronic or otherwise) at least you can get back in the air while you attempt to recreate the rest.
Happy flying!
Happy flying!
