I am in desperate need of info on pop rivet pullers. I am pop riveting on the z brackets on the gas tank. Got half done then the puller decided to cut the stem off instead of pulling it. Figured it was broke so went and bought a new one. That one cut the stem off the first pull. What in the world is going on. Do you need a certain "aviation" puller for the pop rivets? I absolutely cant figure out why it's cutting the stem now. We made sure the puller was perfectly straight up and down before pulling and it worked on one but the next cut it off again. I now have 3 z brakets with one pop rivet in with stems cut off. Can someone please tell me what's going on? I used this stupid thing on all the pop rivets in the empenage and ailerons. Now it doesn't work. Please help.......
