TomVal
FWIW…
Techniques to avoid pilot induced takeoff / departure mishaps start with good checklist discipline. Perhaps the most important application of good checklist discipline is to DO NOT HURRY.
Many pilots also use acronyms just prior to taking the runway as a final check of critical items for departure. I would like to mention an additional technique that I use called “Flow Patterns”.
As an ex-military / airline type, I like to use a last look flow pattern that is custom to my RV-12 cockpit. By “flow” I mean the hand and eyes move in a smooth continuous motion overlooking critical cockpit items. For example on my RV-12 (non-standard cockpit) I use the following flow:
Fuel Valve – Push Open
Flaps – Set for Takeoff
Pax – Confirm “Ready for Takeoff” & visually check seat belt for securely fastened
Canopy – Closed and Latched
My Seat Belt – Recheck for securely fastened
Trim – Set for Takeoff
Flight & Engine Instruments – Normal, No Warnings
Lights – On as required
Camera – Transponder ON
Action – Cleared for Takeoff
This last look “flow pattern” is a counter-clockwise flow that can be accomplished in about 15 seconds. Good checklist discipline accompanied by a backup flow pattern or acronym can go a long way towards avoiding a pilot induced surprise during the takeoff and departure phase of flight.
Regards,
Regards,
