As I have posted in my build thread, I'm building in the basement of my NYC townhouse, which is going to make removing the plane an interesting endeavor. I'm going to be doing some slight modifications to the basement exit that will allow the fuselage to be removed to street level. I'm trying to make removal as easy as possible, so I am thinking about not riveting the aft upper skin and upper bulkheads to the fuselage until I get the plane to the hangar. This would significantly reduce the height of the tail, which will help when I have to angle the fuselage through the opening to the street. However, I want to complete the canopy work before removing the fuselage.
So my question is--will there be any interference issues between the canopy and the clecos holding the aft upper skin on? Maybe I could cleco from the inside? Are there any other issues than the clecos that I'm missing that would make this not feasible?
