Dbro172
It seems pretty simple to install a steinair (or similar) eyeball vent in the horizontal surface of the glare shield, pointing up at the windscreen.... This would be plumbed from a scat tube vertically off the top of the cabin heat baffle Box/cover. When you turn the cabin heat on, if you want to deflect some warm air to the windscreen you just open the vent. This would also mix the air a bit, as opposed to just blowing at your feet.
This has to have been done before, no? Thoughts?
