vernhendershott
I have had to send the following to Van's, my left spar has two rib clips that are teh wrong size for their location. This should be a real mess to get fixed.
"Today turned out to be not much fun, as we were following the instructions on page 15-5 step 2 we found that the 6th and 7th ribs in from the tip would line up with the spar but the holes in the rib clip were about 0.2500 to close to the spar so that the ribs could not be riveted to the clip. In these two location the holes in the rib clip need to be about 0.8000 from the face of the spar (at the top and bottom of the spar) and the ones attached to this spar are at 0.5500 from the face of the spar. This would be the correct rib clip for the next two inboard ribs, so I assume that when the spar was assembled the person selected the wrong rib clips and the quality system failed to see the problem. The serial number for the spar is PP8T8-12164 L."
Best regards,
Vern
Best regards,
Vern
