Pilottonny
Hello guys,
I am wondering if my Commant Belly Whip Antenna is defective! My TruTrak AP plays up when I key the mike. Suggestions were made that it may be a defective antenna. Also see the following thread: http://www.vansairforce.com/community/showthread.php?t=20487
I am wondering if the whip of the antenna and the centre pin of the connecter need to be connected together. Checking with a continuity tester gives no result. But on the other hand when I check my ELT antenna, the centre pin is connected directly to the antenna rod (no resistance) and the ELT works fine.
I would like to know if I can just hook up the the ELT antenna to my radio to see if the problem with my Trutrak AP is due to the antenna, or is that going to hurt my SL30 comm?
Any advise welcome,
Kind regards, Tonny.
Any advise welcome,
