I'm planning a trip January 2 to Deer Valley for 7 days. Are there free tie downs at the terminal? I will go to self refueling on the north side. RV6A.
Thanks in advance and Merry Christmas!
The free transit tie downs are in front of the term building and are usually available. It would be your easiest in and out for your car travel needs as well. If you park at cutter you will most likely get charged and they are on both sides of the terminal. The terminal is on the south side and the SS is on the north side. Our hanger is diagonal to the NE of the SS on the front row and close by. Usually I am out there so if you see a white small truck over there stop by and say hi. Larry
