Dedicated Pitot/Static Ports
HFS
I'm sure this idea is not new - just haven't seen it here before, so -
I build in to the pitot/static system a set of dedicated ports to facilitate easy testing - for whatever reason.
On certificated airplanes I used to fly, sometimes the "tech" would create more problems than he/she was trying to solve when "breaking" into the P/S system for a test port.
Mine live in a spot convenient for access when sitting in the cockpit, without undue "gymnastics" to make the connections. Behind the panel on lower LH side.
Two, long (~5') vinyl tubes, labeled P & S with AN818-4 coupling nuts on one end, and open on the other are attached for test purposes - o/w the ports are capped off with AN929-6 cap nuts, labeled P & S so I don't forget which port is which.
Been using them on my Rocket for 20 years (BD on the 15th) & no leaks from their presence - did the test yesterday, and the longest part of the process was the leakdown waiting time.
HFS
YMMV - But this is a simple, reliable way to make this easier.
FWIW - In the photo you can see the tubing (light blue) used for plumbing the P/S system - it's 1/8" i.d. silicone fuel hose for RC models, over nylon barbed fittings, secured with mini cable ties. Light, flexible, easy to install/replace, and pretty much bullet proof from a standpoint of durability.
  • Pitot:Static Port.jpg
